eico: 666; Tube & Transistor-Tester Deluxe
? eico: 666; Tube & Transistor-Tester Deluxe
16.Oct.14 05:30
Richard Fraser (USA)
Articles: 2
Count of Thanks: 10
I have purchased an Eico 666,I am cleaning and testing this unit. I have read some modifications for this unit, diodes mounted to the meter leads. Would this be a good modification and can they be mounted to the wires other end away from the meter? Seems it would be easier then mounting directly to meter connections. Would there be any other mods to make for durability and reliability? All information would be appreciated. Richard
16.Oct.14 06:21
13 from 3745
Rik Line (USA)
Articles: 8
Count of Thanks: 12
Richard, I'm having trouble adding a link so Google this: buying, restoring and calibrating an eico 666/667 You are looking for a document called restr666.txt and it usually comes up as the first hit. I'm not sure if you had seen this yet, but it's an excellent resource. Best, Rik w2rik
Eico 666
18.Oct.14 02:52
116 from 3745
Articles: 2
Count of Thanks: 11
Thanks Rik the information was what I needed I finished the tester, calibrated it and is working great. Richard
Eico 666
18.Oct.14 03:26
120 from 3745
Rik Line (USA)
Articles: 8
Count of Thanks: 13
Awesome! I'm glad that I was able to point you in the right direction! Best, Rik
Eico 666
18.Oct.14 03:35
121 from 3745
Rik Line (USA)
Articles: 8
Count of Thanks: 11
Richard, Send me an email and I will send you some tube data for the Eico 666 that someone was kind enough to pass on to me. w2rik@arrl.net Best, Rik
Eico's 666 reply
27.Jun.15 00:40
727 from 3745
Vince Adams (USA)
Count of Thanks: 12
Vince Adams
thanks for the tip's. i am in the market for one off Ebay. I'll chk the info right away
Vince Adams
