elektronik: EMG-1341 (EMG1341); Orivohm
02.Aug.07 20:53
2238
Laszlo Biro (H)
Articles: 2
Count of Thanks: 11
Orivohm is a very handy and durable VTVM fro everyday use. Simple, reliable.
Modes: AC Voltage 0.1 - 300 V
            Frequency range: 30 Hz - 25 MHz
            Input impedance: 300 kOhm || 20 pF
            Accuracy : +/- 5 %
            Ranges: 3 - 10 - 30 - 100 - 300 V
            DC Voltage 0.1 - 1000 V
            Input resistance: 15 MOhm
            Accuracy : +/- 3 %
            Ranges: 3 - 10 - 30 - 100 - 300 - 1000 V
            DC zero indicator: In every DC ranges
            Accuracy: +/- 1.5 %
            Ohmmeter: 0.2 Ohm - 1000 MOhm
            Supply voltage: 3 V
            Mid-scale points: 1 - 10 - 100 Ohms
                                     10k - 100k - 1M Ohms
            Accuracy: Between 0.1k -  100k +/- 5 %
                                         100k - 10M +/- 10 %
                                         otherwise   +/- 20 %
            Warning!!! In the lower ranges ( x1 Ohm, x10 Ohm the measuring current can be up to 300 mA!!!
                           That means that tose ranges are not suitable to check semiconductors!!!
