fada:  ; 172 FADA
This article refers to the model: 172 (Fada Radio & Electric Co.; Long Island (NY))
? fada:  ; 172 FADA
01.Oct.10 16:14
64
Merlin Fisher (USA)
Articles: 18
Count of Thanks: 11
 Have a FADA 172 radio  my ? is the frame is charged with 120 volts when on. Found that if I unbolt the Electro cond block it goes away. can  there be a short with in this block? Anybody ever had this happen to them or is the way.  Merl      PS I'm a new be on some of this thanks
Fada 172 hot chassis
04.Oct.10 08:59
64 from 3063
Thomas Albrecht (USA)
Officer
Articles: 378
Count of Thanks: 13
Thomas Albrecht
Hi Merlin,
Assuming the ground symbols on the schematic are connected to chassis, this radio has a hot chassis design.  Note that one side of the line cord is connected directly to ground through the power switch.
Check how yours is wired -- if one of the connections from the power switch goes to chassis ground, then this is a hot chassis design.
Sometimes the ground symbol on the schematic is not connected to the chassis, and the chassis is connected to this "ground" through a capacitor.  If that is the case on this radio, then a short in that particular capacitor could result in a hot chassis which is disconnected when you remove the connection to the capacitor.
Best regards,
Tom
