travler: fixing radio's
This article refers to the model: 5091 (Trav-Ler Karenola Radio & Television Corp.(Travler); Chicago)
12.Jan.17 02:24
1383
I would like to pass on my experience, fixing Trav'ler 5091 a USA import to fellow enthusists. Fault- massive hum -filter condenser measured 0.5uf -Replaced, also the ferrite rod antenna coil broken in two places The rod was very thin, have not seen one like it. I fit one from a scrap radio , the rod was much fatter ,and had to use a file to widen the slot .The radio works well .
