freshmanco: Fresfman Masterpiece 5F4
? freshmanco: Fresfman Masterpiece 5F4
02.Oct.11 20:04
38
Ron Carroll (USA)
Count of Thanks: 11
Hi,
I am new to the forum and need a little help. I have a Freshman Masterpiece 5F4, but none of the schematic I can find have the same terminals. The layout that I have is as follows.
  AERIAL   GROUND     A-    A+     B-     B+     B+AMP
I have built a battery eliminator K101, but need to know the correct voltages before I attch it to the radio.
I belive they should be.
AREIAL  = ANTENNA
GROUND  = NOT SURE
A-    = -5v
A+   = +5v
B-    = NOT SURE
B+   = +45V
B+AMP  = +90V
If some one could verify the voltage and advise as to the others I would be appricative.
Thanks
RC
5F4 supply
04.Oct.11 13:27
38 von 2768
Articles: 2316
Count of Thanks: 8
Aerial = Antenna
Ground = connect with waterpipe (sometimes not required; try !)
A- and A+ = 5 V DC ( originally 6 V storage battery)
B- = 0 V   (internally connected with A+)
B+ = 45 V (works between 30 and 70V)
B+Amp = 90 V (do not increase: there is no grid bias!)
Good luck,
KoBi
