garrard: 210
? garrard: 210
03.Jan.13 21:10
18
Devendra Singh Dhariwal (IND)
Articles: 2
Count of Thanks: 15
Hi, I am trying to restore a Garrard 210 which was in a Murphy Console.
I have managed to get it back in order manually but the auto function does not work.
Any advice on how to go about it?
Thanks in advance.
Dev
Garrard 210
03.Jan.13 22:03
18 von 2946
Howard Craven (GB)
Articles: 95
Count of Thanks: 20
Hello Devendra,
What is wrong with the auto-mechanism ? If the platter slows down to a stop when the auto-mechanism is activated then you will need to re-lubricate all the mechanism's moving parts as the original grease will have solidified. I use Castrol LM (low melting point) grease which is usually used in car wheel bearings. Use light machine oil sparingly to lubricate the spindle, intermediate bearing and motor bearings.
Regards .... Howard Craven, Surrey, England
Thread locked Thread closed by a moderator. But replies can be made through a moderator.
