grundig: 3035W/3D/USA;
? grundig: 3035W/3D/USA;
06.Sep.13 21:00
46
Ross Hoff (USA)
Articles: 15
Count of Thanks: 9
Ross Hoff
            I have a 3035W/3D/USA that plays very well, but when it is first turned on AM broadcast it plays for a few seconds then the signal drops to almost nothing for a short time then comes back to normal and plays well. It does not do this on FM, if I play it on FM first,then go to broadcast it is OK,can anyone help me find the problem and correct it?   Thank you, Ross W. Hoff
A first hint
07.Sep.13 13:30
46 von 2767
Ottmar Lauth (D)
Articles: 221
Count of Thanks: 8
Ottmar Lauth
Dear Mr. Hoff,
after I have looked at the schematic of the European version of this radio ( 3035/3 D ) I assume that there is a default in the AVC branch that connects the AM - diode with the steering grid of the ECH 81.So I would advise you to check the following items : C 49, R 10 and R 20.
I wish you good luck with repairing your Grundig set.
Yours sincerely.
Ottmar Lauth
3035W/3D/USA
07.Sep.13 21:31
69 von 2767
Ross Hoff (USA)
Articles: 15
Count of Thanks: 8
Ross Hoff
    Dear Mr. Lauth, Thank you for your quick reply and suggestion. I took your advice and checked C49,R10 and R20, didn't find anything out of order, so I'm still looking for the problem, thanks again, Ross W. Hoff
