grundig: 5299 Stereo; Steuergerät
? grundig: 5299 Stereo; Steuergerät
04.Mar.11 19:54
137
Ross Hoff (USA)
Articles: 15
Count of Thanks: 22
Ross Hoff
   I recently acquired a 5299 Grundig, it has a tuning eye on the right side of the dial, I would like to know what the small bulb indicator on the left side is. Is it suppose to operate when the stereo function is activated? The bulb on mine is burned out, where can I get one to replace it? Thank you, Ross W. Hoff
bulb
10.Mar.11 13:19
137 von 3128
Articles: 2316
Count of Thanks: 22
It is a 7 V / 100 mA type.
Herr Knoll was so kind to tell me:
The function is to indicate FM "AFC on". If you push the tuning knob the indication should go off. The function is activated by the key FA-AS (for German version, no idea what on Export model).
In AM mode the key switches the ferrite rod antenna on/off.
Good luck,
KoBi
