Grundig 7064 WF/3D cabinet
? Grundig 7064 WF/3D cabinet
Count of Thanks: 11
I have obtained a Grundig Konzertschrank 7064 WF/3D. The front upper cabinet door ( covers the record player section) hinge pin is loose on the right side, causing damage to the cabinet..
I wish to remove the door to repair the hinge,and the cabinet wood, but haven't figured out how to do so.It appears that the door was assembled with spring pins or posts that protrude into the right and left cabinet walls but I have not been able to see how to retract these pins. Any advice about how to do this in the least invasive manner would be most welcome.
Thanks
Alex
model without photos
Hello Mr Bayne,
Can you please upload your model's photos before?
In that way the model's page will be more complete and someone can give some answer to your question.
Cordially,
Bruno Gandolfo.
