Grundig 7064 WF/3D cabinet
? Grundig 7064 WF/3D cabinet
20.Nov.11 19:49
217
Alex Bayne (USA)
Count of Thanks: 10
I have obtained a Grundig Konzertschrank 7064 WF/3D. The front  upper cabinet door ( covers the record player section) hinge pin is loose on the right side, causing damage to the cabinet..
I wish to remove the door to repair the hinge,and the cabinet wood, but haven't figured out how to do so.It appears that the door was assembled with spring pins or posts that protrude into the right and left cabinet walls but I have not been able to see how to retract these pins. Any advice about how to do this in the least invasive manner would be most welcome.
Thanks
Alex
model without photos
25.Jun.12 06:31
217 from 2440
Bruno Gandolfo-Canepa (RCH)
Articles: 132
Count of Thanks: 4
Hello Mr Bayne,
Can you please upload your model's photos before?
In that way the model's page will be more complete and someone can give some answer to your question.
Cordially,
Bruno Gandolfo.
