grundig: c/St Ch= HF45; Stereo-Konzertschrank Man
? grundig: c/St Ch= HF45; Stereo-Konzertschrank Man
![Mario Coelho](https://www.radiomuseum.org/image.cfm?image=marioc.jpg&width=120&height=140)
Dear Radiofriends
I need help to repair a Mondello ST.
The UKW/FM contact botton doesn't work at all. The nonfunction seems to be a contact defaut.
I've tried to repair it, but I couldn't read the schematic instructions text in Rmorg archive sheets because it is written in German language.
The Google translater was not usefull to me, because it is not technical and some terms are not translated meaning this proposal.
Do You help me to understand, how do I do, to pull out the FM's contacts blade?
Chassis and dial glass is already out. Now I've to locate a spring to take it away. Am I right?
Does this move release the blade?
Well. I can't understand the text in German at all. Forgive me but give me some help, please.
Cordially
Mário
GRUNDIG Tasten reparieren
![Hans M. Knoll](https://www.radiomuseum.org/image.cfm?image=hans_1~~1.jpg&width=120&height=140)
Hello Mario.
on this Modell RTV350 you can find pictures for repair these Levers.
knoll
Thank You so much
Hello
Mr. Hans Knoll
Once again I got your kind help.
Thank You very much for your prompt reply.
Now, safely, the blade is out.
Cordially
Mario
Attention
Hello Mario.
Work at reinserting the slide very carefully.
The contact -Springs are very sensitive to bend.
Gruss Hans
Attention
Thank You again
I´ll do my best.
Gruss Mario
