grundig: Cub
grundig: Cub
         This model has 5 Transistors: TR1&2: OC71, TR3&4: OC72 & TR5: OC602 ( Motor Speed Control). Later models used Japanese equivalents to TR1&2. Later models used OC74 for TR3&4.
The speaker is a 6"x3" Eliptical Permanent Magnet Dynamic (PDyn) Moving Coil, 3.5 Ohms impedance. The amplifier output/power is given as 100mW.
Tape speed is 3¾ ins. per second (mean).
Overall size of machine is: 11"(w) x 3.5"(h) x 6.5"(d). The case is made of modern plastic.
Introduced into Great Britain in 1959. Please note: This model does NOT have a "magic eye" recording indicator.
Source of Data: Grundig(GB) User Instructions & Specifications. Grundig(GB) Service Sheets. The Grundig TK1 & Cub Guide by Focal Press (1961)
Model Changes
Dear Anthony,
It is better that you suggest these changes by filling in the "Suggest Change" sheet which you get by clicking on "Suggest Change" at the bottom of the model page. Otherwise someone else has to do it (and you get no credit!).
These suggested changes are then reviewed and when accepted are automatically included on the model page and you are e-mailed to tell you or to ask for clarification.
Thank you.
Regards,
Roy
         Many thanks Roy,
I have followed your advice and submitted it through the "Suggest Change" option.
Regards Tony.
