grundig: Philips Mignon in a Grundig radio
24.Jul.04 20:34
Rolf Zetterberg (S)
Articles: 22
Count of Thanks: 10
Last week at an auction I bought a Grundig 1099 with a Philips Mignon record player in it.This is a radio with a rather unusual slot for the 45rpm records at the right side and not in the front as is common on other similar models.After making four new rubber pillows,it worked fine.I've seen this player in some other radios,for example in a Swedish Conserton-but they were all using Philips chassis.My question is:Was this Philips Mignon player ever used by any other manufacturer?
Philips Mignon player in other radios
26.Jul.04 18:19
Martin Renz (D)
Officer
Articles: 579
Count of Thanks: 10
Martin Renz
Hi Rolf,
You can find some information at this Dutch webside:
http://www.hupse.nl/radio/frameset.htm?philips_ag2100.htm&ContentFrame
the according radios at RM are:
Grundig with player http://www.radiomuseum.org/dsp_modell.cfm?model_id=22107
same witout player http://www.radiomuseum.org/dsp_modell.cfm?model_id=22089
Loewe with player http://www.radiomuseum.org/dsp_modell.cfm?model_id=21720
Philips player http://www.radiomuseum.org/dsp_modell.cfm?model_id=21514
If you need help with the dutch translation, you could ask Alard Roose here at RM, I am shure he will help you if you ask him.
yours
Martin Renz
