grundig: SO302U/S; Stereo/Mono Problem
? grundig: SO302U/S; Stereo/Mono Problem
06.Jul.13 01:58
20
Craig Vodnik (USA)
Articles: 48
Count of Thanks: 14
Craig Vodnik
I have had my stereo working well and went to finally do the refinishing of the cabinet.  I had set aside the electronics during the process, but when I went to put everything back together, the volume level of the "stereo" setting is significantly lower.  When I push the button for "mono", the sound is great.
I thought that this might be something simple since I had previously changed out all the capacitors and decided to check the resistors, which I had never investigated.  I figured that something around the stereo/mono switch might be the problem.
I tested all the resistors and found a few slightly out of whack, but 3 in particular interested me:
R45 and R46 - Both are testing around 1.8k, while they should be at 3.9k.  While this is odd, I focused my attention on the next issue, which seemed more pressing.
R61 should be 1k, but my multimeter showed 0 flat.  I thought that this was odd, tested the same resistor 3 or 4 times in between testing other ones that all showed the correct value.  Every time that I tested R61, it showed 0k.
I swapped out the resistor with a new 1k resistor, which I tested before installing and it read 1k correctly.  As soon as I soldered it in, the reading on the multimeter showed 0 flat.  Befuddled, I checked the resistor that I cut out and it read nearly a perfect 1k.
Completely confused, I turn to the group to see what I might be doing wrong.  This might not even be the cause of my stereo/mono problem, but I need to start somewhere.
Thanks in advance!
Measuring parts
06.Jul.13 11:17
20 from 2812
Michael Watterson (IRL)
Articles: 1126
Count of Thanks: 17
You often can't reliably measure resistors. coils or capacitors or transistors in circuit. At least one connection (two on a transistor) needs to be disconnected.
Also except for a few circuit locations tolerances to operate OK are usually much wider than the component tolerances. It sounds like a wiring error or switch fault.
Determining Real Problem
06.Jul.13 19:40
54 from 2812
Craig Vodnik (USA)
Articles: 48
Count of Thanks: 16
Craig Vodnik
Hi Michael,
Thanks for the quick feedback.
After looking things over, I have a couple of items:
1. I was applying heat to the shaft in order to loosen the dried grease so that I could manually turn the balance dial.  Not sure if I might have screwed up something doing this, but while I had the stereo apart for refinishing, I thought that I would try and solve this problem.
2. I looked at the switch and the schematics, but am unable to see an obvious place where there's a problem.  How can I test to determine what the problem is?  Are there some existing forum posts that I can reference?
Thanks.
craig.
