nordmende: How to use the "Bandbreite schaltbar"of Nordmende Tannhäuser
? nordmende: How to use the "Bandbreite schaltbar"of Nordmende Tannhäuser
08.Jul.16 17:31
104
Jiandong Han (PRC)
Count of Thanks: 8
Model: Nordmende Tannhäuser-Stereo 60 U330
Dear firiends, I don't know how to use the "Bandbreite schaltbar"of the radio.
Pull or push the left knob to change bandwidth wide or narrow?
It's too tight, I'm afrid to force the knob.
Thank's a lot for your help.
Bandbreite - ziehen
10.Jul.16 20:47
104 de 2347
Henning Oelkers (D)
Articles: 585
Count of Thanks: 8
Henning Oelkers
Usually to activate "narrow" you have to pull the Volume Control ( travel is apx 5 mm ), to swicht back to "wide" you push the Knob back.
Please check, if the Volume Pot is still the original one, by checking from inside of the Radio.
Please also remove the Volume Knob(s) and try again.
Knobs schould be mounted while the Shaft is in the "wide" Position, to avoid the Dial Glas from blocking the Switch.
hope this helps,
Best Regards,
Henning
