marconi: 534;
? marconi: 534;
28.May.15 20:58
124
Ralph Besser (CDN)
Count of Thanks: 7
hello all.
I need some help with some tube substitutions. I acquired an Marconi model 534 from Great Britan and I cannot find any North American substitutes for the British numbers.
can anyone help me on this?
the tube numbers are W42, X42, D41, H42 , N42 and U14
thank-you in advance, Ralph Besser
no direct substitutes
03.Jun.15 21:11
124 from 2184
Mark Hippenstiel (D)
Articles: 1192
Count of Thanks: 6
Mark Hippenstiel
Hello Ralph,
I am relatively certain that there were no "North American" substitute types, if you think along the lines of, say, 42, 80, 6A8 and the like.
However, there were equivalents and exchangable types from Cossor, Ever-Ready, Ferranti, Mullard, Mazda (Ediswan UK), Standard (Valve) and Six-Sixty.
You might have to try and acquire one of those or the original ones for your set. In the meantime, I can give you some information from the Mullard Catalog of Master Valves 1937. They say "it should be remembered that all types are not directly exchangeable". So this list is just a help and a start of investigation.
  • X42 ≈ FC4
  • D41 ≈ 2D4A
  • N42 ≈ Pen4VA
  • U14 ≈ DW4, DW4/500
The Cossor Valve Manual 1935-6 has the following "equivalents":
  • U14 = 460BU
Unfortunately, their list of recommended tube substitutes for commercial receivers (including Marconiphone) does not yet include model 534 and I don't have a later edition.
r-type.org has an extensive list of equivalents. No warranty given of course.
  • W42 = CV1183, NR61
  • X42 = 15A2, CV3576, MX40, FC4, VHT4, 41MPG, A80A
  • D41 = CV1170, CV1187, NR46, NR66
  • H42 = none given
  • N42 = KT42
  • U12/14 = AU3, CV1064, CV1796, DW4-500, DW4/350, NU3, R4, UU120/350, VU64
Good luck!
Kind regards
Mark
This thread was moved automatically.
This question was moved automatically to the board "Talk" to get more possibilities for answers.
Moved from board »* TALK - visible for members only« on 03.06.2015 20:58:58 from automatically
Brans 1953
03.Jun.15 22:23
140 from 2184
Articles: 1192
Count of Thanks: 9
Mark Hippenstiel
To complete the picture, I'll include the information from P. H. Brans Equivalent Radio Tubes Vade-Mecum (10th edition, 1953). It only lists replacement types, all of which but two have a different base.
  • W42
    • 6R6G - A2, B1, D2-3
    • EF117 - A2, B1, C5, D2-3, E1-2
    • HP1118 - A2, B1, C5, D2-3, E1-2
    • RV12P2001 - - A2, B1, C2-5, D1-2-3, E1-2
    • W76 - B1
  • X42
    • X63 - A2, B1
  • D41
    • not listed
  • H42
    • 6AD5G(T) - A2, B1
    • 6F5(G, GT, MG) - A2, B1
    • 6SF5(GT, GT/G) - A2, B1
    • 7B4 - A2, B1
    • 12F5GT - A2, B1
    • 12SF5(GT) - A2, B1
    • H63 - A2, B1
  • N42
    • not listed
  • U14
    • = 460BU
Explanation:
  • A2 = different base
  • B1 = different current and voltage
  • C2 = different impedance
  • C5 = different frequency limit
  • D1 = different anode voltage
  • D2 = different screen grid voltage
  • D3 = different control-grid polarisation voltage
  • E1 = different anode current
  • E2 = different screen grid current
Regards,
Mark
Moved from board »* TALK - visible for members only« on 04.Jun.15 12:22 from Mark Hippenstiel
