meek: The Meepon
? meek: The Meepon
I have a Meepon Crystal Set,registered with PostMaster General in USA,the panel is similar to the one already depicted on Radiomuseum,apart the tuning scale, that is directly engraved on the panel, and a different cat's whisker detector , the box is slightly different in size and the lock.This version,is said to be a british crystal set manufactured in USA,as found on stonevintageradio.com web page,under Crystal Radio .
(copy anThe only difference with my Meepon would be the presence of an high/low switch.
Attachments:To thank the Author because you find the post helpful or well done.
Meepon
Hello Sig.Marra,
Yours is the so called No.2 set, which is now available. The pics have been moved.
Ref.: Sanders, Tickling the Crystal, vol.4, pp.223 to 225.
