meek: The Meepon
? meek: The Meepon
03.Feb.13 10:53
97
Antonio Marra (I)
Articles: 19
Count of Thanks: 15
Antonio Marra
I have  a Meepon Crystal Set,registered with PostMaster General in USA,the panel is similar to the one already depicted on Radiomuseum,apart the tuning scale, that is directly engraved on the panel, and a different cat's whisker  detector , the box is slightly different in size and the lock.This version,is said to be a british crystal set manufactured in USA,as found on stonevintageradio.com web page,under  Crystal Radio .
(copy anThe only difference with my Meepon would be the presence of an high/low switch.
Meepon
10.Feb.13 16:00
97 von 2548
Articles: 2316
Count of Thanks: 7
Hello Sig.Marra,
Yours is the so called No.2 set, which is now available. The pics have been moved.
Ref.: Sanders, Tickling the Crystal, vol.4, pp.223 to 225.
