moscowrtv: Rubin - Рубин
29.Aug.11 10:34
98
Peter Veldman (NL)
Articles: 6
Count of Thanks: 12
he guyssorry for my grammar
i recently found this tv
and the pictiure tube was brolen and the cabinet is drenched in tar and beewax
so my mission make a log of me repairing it
so at firsth i had to w8 a week becaus i was in Czecho when i got it
and when i got home i started disasembeling
backside is warped so it sits under a radio until it is strait
demounted the top chasi and removed the pictiure tube
 bothem chasie is stil mounted
and evrything looks great at the bothem
so no i need to find a tube and clean the outside
i will update this topic as much as i can
tips are helpful so if sombody can deciver rusian i would be happy
to continiu
04.Sep.11 19:45
98 von 2857
Peter Veldman (NL)
Articles: 6
Count of Thanks: 9
well to continiu
i bought a grundig 336 and took the tube (MW43-64)
this should be the right tube
but when i tested it nothing
and whan i looked at the voltages i noticed the 0.5A fuse had blown
putted a peace of aluminium in it to test
the rectivier tube started sparking
but it worked (tube is now broken)
so now i need to buy a 5z4
all looked nice didnt got pictures tube lasted not long enough
now i need to rotate the coils  (picture was sloped)
and adjust all the pots
pictures of it working soon
back again
08.Mar.12 06:43
276 von 2857
Peter Veldman (NL)
Articles: 6
Count of Thanks: 15
well i forgot to update you guys
so here it comes
the 5z4 wassent broken but my block of aluminum stoped conducting
so i switched it to a real fuse and it worked again
my rf converter at that time did not work so i could not tune it (or get it to work)
i got a tip from somone for a conferter with a barberic control
so i got sound on chanal 1-2 i have sound (sound tuned to the russian set and the set daild into europ chanal 1)
no picture
so i went asking around and found nothing
and one evening i started turning on the vertical sync
ping picture
and after 1 week the switch on the tuner got stuck
so you can turn the picture tube of for record players
and that was the last i did that time
after almost a year i took it out of my storage (almost broke my back with it)
to fix a switch on the tuner
but i disasembled it good
and went to work with some restore a finish
restored the switch
putted it together
it looks almost new now
and afster that i finished adusting the focus magnets from the new picture tube
placed the back panel back and only the bottem panel is left to do
some pictures wil come soon becaus it is kind of epic now
