nordmende: 1/616US; Parsifal-us
? nordmende: 1/616US; Parsifal-us
Hello: I recently recived on of these radios. It works fine on BC and SW1. Does not seem to have any reception on SW2 although I am not using an external antenna. The main problem I am inquiring about has to do with only getting reception on FM from 88 to about 100mhz. After that there is no static, no change on the magic eye, nothing. I have not recapped it yet but it sounds nice on both channels. When I put a working ECC 85 from another working radio on this radio reception deteriorates even more, yet the ECC85 from this radio works fine in others. Hopefully someone has already solved a similar problem and can point me in the right direction, Thanks.
PS: the dial glass was broken during shipping. I would be glad to use a non-export one on mine. If you have one for sale, please let me know.
Parsifal
for the european dial glass look there ==> Dial glass Parsifal
Regards WB.
Thank You
I contacted Hans and the glass is no longer available. Anyone with one available, please let me know.
