nordmende: 5/602; Transita TS de Luxe
? nordmende: 5/602; Transita TS de Luxe
19.Oct.10 23:18
Felice Nicolini (I)
Articles: 13
Count of Thanks: 10
Good evening.
Radiomuseum currently does not publish any pictures of the interior of models Nordmende TS de luxe. Having no special technical knowledge, I do not see significant elements to distinguish the three models offered on the site. My device has a label with code 865.602.00. Corresponds it to the model shown as transit TS de Luxe 5 / 602?
If it so is, my model has one screw on the glass, at the center, behind the keys, while on the page dedicated to the 5 / 602 there is a similar picture (the second) and two photos (the third and fourth) that refer to a model with "at least" two screws. I say at least, because the model 1966/67 has three screws (photo 2) and this probably can be seen also from the photo of the model of 1967/68.
What should I do?
Radiomuseum non pubblica attualmente alcuna foto d'interni del modello Nordmende TS de luxe. Non essendo un tecnico, non vedo elementi significativi per distinguere i tre modelli proposti sul sito. Il mio apparecchio porta una targhetta con il codice 865.602.00. Corrisponde al modello indicato come Transita TS de Luxe 5/602?
Se così fosse, il mio modello ha sul vetro una sola vite, al centro, dietro i tasti, mentre sulla pagina dedicata al 5/602 c'è sia una foto in tal senso ( la seconda) che due foto ( la terza e la quarta) che si riferiscono ad un modello con almeno due viti laterali. Dico almeno, perchè il modello del 1966/67 ne possiede tre ( foto n. 2) e questo si desume probabilmente anche dalla foto del modello del 1967/68.
Che cosa devo fare?
This thread was moved automatically.
This question was moved automatically to the board "Talk" to get more possibilities for answers.
Moved from board »RADIO MODELS DISPLAYED« on 25.Oct.10 23:18 from automatically
Nordmende Tranita TS
23.Jan.11 16:52
187 von 3298
Articles: 2321
Count of Thanks: 9
Moved from board »* TALK - visible for members only« on 23.Jan.11 17:17 from Wolfgang Bauer
