nordmende: Nordmende Othello Dial Lamp Question
? nordmende: Nordmende Othello Dial Lamp Question
05.May.10 10:41
23
Bob Isaac (USA)
Articles: 107
Count of Thanks: 18
Bob Isaac
For the life of me, I cannot find the pilot lamp specifications on the schematic for the Nordmende Othello 53.  Does anyone know what this type if bulb is?  All I know is that it is a scew base type of lamp.
I also have the same question for the SNR Excelsior 52. Can someone help?
Thank you
Bob
Nordmende Othello Pilot Lamp
05.May.10 12:15
23 de 3788
Felix Schaffhauser (CH)
Articles: 189
Count of Thanks: 21
Felix Schaffhauser
Hello,
I have the schematic of the Othello 55 in front of me:
there are two pilot lamps wired in parallel with the heater winding.
 The electrical specification is:
V = 7 Volts; I = 0.3 Amps
mechanically they conform to the E10 socket specs. (10 mm screw socket).
I trust that Your model uses they same lamps.
Felix Schaffhauser
Found Some!
06.May.10 00:42
63 de 3788
Bob Isaac (USA)
Articles: 107
Count of Thanks: 19
Bob Isaac
Thank you Felix,
 I beleive that I can get these at buerklin.com
They have them listed as: Filament lamps with E 10 socket 7.0 V/300 mA/2.1 W
.33 euro each if I buy 10.  Not too bad!
<EDIT>
I spoke too soon.  Buerklin evidently does not sell to the general public, so the hunt is back on again...
Source for Pilot Lamps
07.May.10 11:45
151 de 3788
Bob Isaac (USA)
Articles: 107
Count of Thanks: 19
Bob Isaac
OK, all is good!
I found the lamps online at HENRI-electronic GmbH, at .65 euro each.  You do have to order a minimum of 12 euro, so I went ahead and ordered some elctrolytics that I need.  Their prices aren't too bad.
