nordmende: V13 Ch= 4/613; Elektra
? nordmende: V13 Ch= 4/613; Elektra
05.Jul.13 21:27
30
Tom Seeger (CDN)
Articles: 6
Count of Thanks: 7
Tom Seeger
Hello. I have repaired an Elektra 4/613. It needed only a few capacitors in the audio section to be replaced, and now sounds and plays wonderfully. Only one minor problem remains. The FM stations are about 1 MHz lower than they should be at the top of the band around 106 MHz. At 90 MHz the tracking is quite acceptable. The sensitivity is very good across the entire band.
Unfortunately I do not speak German, so I can not follow the alignment procedure available on this website. I wonder if someone could tell me which adjustment would improve the tracking at the high end of the band.
Regards Tom
06.Jul.13 08:30
30 von 2727
Articles: 2322
Count of Thanks: 10
Hallo Tom,
I downloaded the adjustment-manual to the model.
I tried to translate the detail in English.
Best regards WB.
