Suppliers for Vintage Electronics, Radio Parts, Tubes, etc.
![Thomas Albrecht](https://www.radiomuseum.org/image.cfm?image=usa_albrecht_thomas_2012.jpg&width=120&height=140)
The list below shows suppliers in North America for parts and restoration supplies for antique radios, electronic phonographs, tape decks, and TVs. This list is intended for suppliers that serve unique needs in the vintage electronics community, so the big modern electronics supply houses like Mouser, Newark, and Digi-Key are not included.
This list will be edited and kept up to date as new information becomes available. Please contact me via email if you would like to recommend another supplier to add, or if you have had any problems with a listed supplier or find that a supplier is no longer in business.
A similar list is being maintained on the Antique Radio Forum here: ARF Supplier List .
For a similar list of European suppliers, see Aren van Waarde's post below (3rd post in this thread).
Antique Electronic Supply (tubesandmore.com)
Radio Daze (radiodaze.com)
Mark Oppat's Old Radio Parts (oldradioparts.net)
Schematics (besides here at RMorg):
Nostalgia Air - Rider schematics (nostalgiaair.org)
Sams Technical Publishing (samswebsite.com)
Dave and Babylyn Cantelon - Just Radios (justradios.com)
John Kendall - Vintage Electronics (vintage-electronics.com)
New and new old stock (NOS) passive components (capacitors, resistors, wire, controls, lamps, diodes, transformers, coils, etc.):
David Kulka - Studio Electronics (studioelectronics.biz)
WJOE Radio (wjoe.com)
Jim Cross - Vacuum Tubes, Inc. (vacuumtubesinc.com)
ESRC1 Vacuum Tubes (esrcvacuumtubes.com)
Tube Depot (tubedepot.com)
Bob Dobush - Find-a-Tube (findatube.com)
Radio Electric Supply (vacuumtubes.net)
Play Things of the Past (oldradioparts.com)
Radiola Guy (radiolaguy.com)
Dave & JoAnn Frush (email: parts2many at aol dot com)
Julie McCall (email: radiopup at bell south dot net)
Mike Koste - Gobs of Knobs (email: gokmike at gmail dot com)
Barry McDaniel (email: decoradioman at sbcglobal dot net)
Ruthann Mertl (email: ruthannie at mchsi dot com)
Jim Sargeant (email: bsargent at swbell dot net )
Reproduction parts (knobs, pushbuttons, escutcheons, back covers, belts, grommets, shock mounts, clips, wooden cabinet parts, handles, etc.):
Edward Schutz - Renovated Radios (renovatedradios.com)
Grille Cloth:
Plastic dial covers:
Mark Palmquist - Retro Radio Repair (dialcover.com)
Convex glass dial covers:
Speaker reconing, driver repair, and speaker parts (e.g., replacement cones):
Mike Hagan Antique Auto Radio (mikehaganantiqueautoradio.com)
Antique Automobile Radio, Inc. (radiosforoldcars.com)
Vintage Car Radio (vintagecarradio.com)
Classic Car Stereos (classiccarstereos.com)
Phonograph and tape deck parts (idler and pinch roller rebuilding, belts, cartridges/needles, cartridge rebuilding, etc.):
Ed Crockett - Vintage Electronics (vintagelectronics.com)
Vintage TV parts (flyback transformers, yokes, focus coils, vertical output transformers, power transformers, repro backs and HV cages, etc.):
Moyer Electronics (moyerelectronics.com)
Batteries for Antique Radios
Thank you, Tom, that you did solve the question.
We might add also sources for batteries (and other things). I just saw that ...batteries.com does not function - but we know also data.energizer.com (without the 3W). But may be there are specialized services for our concerns?
I add here a few links to articles which deal with this problem:
Very important is NiMH Battery packs for High Voltage.
Connections is an other topic: Replacing special Batteries by Battery Packs.
Naturally charging Ni-MH battery packs is an other problem to solve.
I see that under the term sources this thread is not within the first. Sources (not resources) has therefore to be used here more often like suppliers, supply, vintag, radios, parts, tubes, repair, repairs, reproduction, restoration, renewal, renovation, service, spair, correction, mending, rebuilding etc. I think suppliers and sources are the most wanted?
Suppliers for antique radio parts and tubes in Europe
![Aren van Waarde](https://www.radiomuseum.org/image.cfm?image=nl_vanwaarde_aren_2005.jpg&width=120&height=140)
Regular updates
Dear Tom
Nearly every week you could do some uptading of this most complete list.
The list gets nealy thousand requests per month ... So your work is not in vain.
Thank you very much for this good service!
Cordially,
Ernest, HB9RXQ
The part for Europe has grown substancially
Thanks to Aren van Waarde! Also, he updates regularly with the hints he becomes from members and guests (using the contact form from the bottom link - we will forward to the right person).
It is important that new sources or the changes will not be posted here but told the two members, Thomas Albrecht, USA, or for the other list to Aren van Waarde, NL.
You can always see below posts 1 and 3 when the last update was done.
Thanks for your hints to keep this well up to date.
Pacific TV was mentioned as a source for tubes, but I would like to point out that they are also a good source for some obscure schematics (especially some Canadian products), and have been continually adding more to their library:
Edit: I tried to post the link to their schematic page, but when I try to submit the post, it keeps giving me an error message telling me that my post contains a link.
Anyway, it's easy to find the schematics from Pacific T.V.'s main page.
(Please use the link icon within the editor to set a link, thank you)
UK Vintage Radio Service Data.
This website run by Paul Stenning has nearly all of the UK schematics available at a very reasonable price.
The KB Museum Service data
Service data for Kolster Brandes, ITT-KB, ITT, RGD & Regentone radios and audio exuipment.
Count of Thanks: 107
Having just joined this site, I must say how impressed I am with the amount of supplier information available to members. I have been making notes in a book everytime I encounter a good supplier for parts. I no longer need that book! It's all here!
In these trying times, I'm glad to find a resource like this to explore. I hope to also make contributions with regard to Canadian models and live 1 Km away from the still standing RCA Victor factory in Montreal. I would like to include a link to my local "Tube Guy" in Montreal: Tubebazaar.com
Thanks again, Gary Kuster, Montreal
