One tube Radio + crystal set IN ONE ...
? One tube Radio + crystal set IN ONE ...
31.Jan.10 08:31
52
Zenonas Langaitis (LT)
Articles: 73
Count of Thanks: 19
Zenonas Langaitis
      Small  radio  manufacturer in Lithuania   KARADI,  in 1935 - 1936  produced  radio  set  TAUTOFONAS.  It was battery  one  tube  regenerative  radio + crystal  radio in one case, one schemat.
Radio  coverage  three  waves  - SW  (19 - 50 m), MW, LW.
For  crystal  radio -  used others  earphones  plugs T2 on radio front panel (red plugs)   - for tube radio others T1  (black plugs). See photo...
Used  cathode  grid  VALVO U107D  tube   in schemat --   (analog A141  Philips).
All info - photos and  schemat  are   in RMorg  site >>>>>>>
http://www radiomuseum.org/r/karadi_tautofonas.html
QUESTION :
Do you  know any  analog  radio  set , as this  TAUTOFONAS --  with  one  tube  regenerative  and  crystal  radio in one  case. Which  company  produced  similar  set  - in 1926-1936 ?   By the way - nice moderm  walnut tree case..
Bildbreite editiert, max. 600Pixel breit !!!!!
Crystal set and 1 tube radio
31.Jan.10 12:13
52 from 8967
Gabriel Toth (CZ)
Articles: 128
Count of Thanks: 14
Gabriel Toth
Dear Zenonas,
the model http://www.radiomuseum.org/r/knn_negadyn.html has some similar function, either crystal set with one tube amplifier or one tube negadyn through positive interaction between the grids.
BR, Gabriel
By the way....
31.Jan.10 12:51
68 from 8967
Wolfgang Holtmann (NL)
Articles: 978
Count of Thanks: 23
Wolfgang Holtmann
Dear Gabriel
May I add a minor correction to the drawing above...
The space charge grid is the one next to the filament and normally connected at the screw on the base. It is kept at a positive potential all the time.
Kind regards
Wolfgang
