paillard: 'Export' (38)
Dieser Artikel betrifft das Modell: Export 38 (Paillard AG; St. Croix)
11.May.08 23:27
2097
Heribert Jung (D)
Viktor Cingel:
The schema is drawn in the position of SW,
switch up is for MW and down for LW (as in the original set)
Resistance of input winding of power trafo: 48 Ohm, secondar 2x500Ohm.
Resistance of dynamic winding in laudspeaker 2560 Ohm.
I has to repair thickler for SW: 5 windings, and tuned SW winding (8 w)in oscillator was cut, so this indicated that during the war someone destroyed SW,
which was at that time done in our countries.
If was tuned for 420Khz, in a very good conditions, so I did not touched it.
The input cuircuits as well oscillatro were tuned as described on dial.
The grill damaged, but from a fragment which I found in radio, a copy
was done using very similar grill, colored by green pastel.
The knob is made from wood, with iron ring, a replica was done just from wood
and ring is painted.
