perpetuum: Is this the correct wiring?
This article refers to the model: PE-Stereo 4230 (Perpetuum-Ebner (PE); St.Georgen)
? perpetuum: Is this the correct wiring?
17.Feb.11 02:37
57
Paul E. Pinyot † 2013 (USA)
Articles: 184
Count of Thanks: 9
I am putting the final touches on the Grundig with the PE4230. I want to make sure it is wired correctly.
 Please look at the below schematic and comment. Is this wired properly from A to B?
I have not determined a 60hz capacitor as of yet. The 1.1 uf came with the unit.
I did machine the motor pulley to put the platter on speed for 60hz. I built up the pulley with Bondo auto body putty that some one has filed.  I let the Bondo harden for several weeks. It is hard as a rock. I shaped it with a miniature file and sand paper to a slight convex curve. The belt ride in the middle of the shaped pulley.
Thank you,
Paul.
Per Email from Georg Beckmann
17.Feb.11 22:17
57 von 2705
Vincent de Franco (D)
Articles: 187
Count of Thanks: 8
Vincent de Franco
Hi Paul,
here something I found about the DUAL and PE. It's all in German, but lots of pictures and
contact information, perhaps even a source for spare parts.
Link to the German Phono Museum.
Georg Beckmann
