philips: 371A ;
? philips: 371A ;
18.Jul.11 21:32
Bruce Cohen (NL)
Articles: 310
Count of Thanks: 13
Bruce Cohen
I have got one of those Philips 371A/15.
They seem to be British Made. Some of them seem to have a Philips-Symbol on the left side, and some not.
Does anyone know, how this came about?
Philips 371A badge
18.Jul.11 21:53
7 de 3657
Howard Craven (GB)
Articles: 95
Count of Thanks: 13
Hello Bruce,
The Philips 371As (and 371Us) should all have a badge on the left hand front, Trouble is, they tend to fall off, indeed the badge was missing from my 371A when I acquired it but luckily I managed to find a replacement. It is the same metal badge fitted to many other 1940s Philips sets built in Europe.
Regards ..........Howard
Thanks
19.Jul.11 09:50
68 de 3657
Bruce Cohen (NL)
Articles: 310
Count of Thanks: 12
Bruce Cohen
Thank you, Howard
I thought, they might have run out of it because of the times in the forties ;)
I have to look for a replacement then, one finds copies of the badges in Holland, it will be one of those.
Thanks again!
23.Jul.11 10:34
134 de 3657
Bruce Cohen (NL)
Articles: 310
Count of Thanks: 15
Bruce Cohen
Come to think, Howard, what kind of glue did they use at that time? I cannot spot any residu on the bakelite, and I would expect to see that (see picture in the collection of the radiomuseum). No hole either ... Do you have a picture of your radio, before you fitted the emblem?
Nowadays there are glues that stick as hell - were those available at the time? (Maybe not, you might say, for all the emblems fell off, hihi...)
Philips 371A
23.Jul.11 16:27
169 de 3657
Howard Craven (GB)
Articles: 95
Count of Thanks: 16
Hello Bruce
Here's a pic of my Philips 371A without its badge, there was no glue residue  .....
 I don't know what glue was originally used, but it wasn't very good !
And here is the correct badge for this set, in need of a bit of touch-up paint .....
I used a spot of superglue to stick it on.
Regards ............ Howard
PS: The white paint around the inside rims of the two front knobs is incorrect and has since been removed.
23.Jul.11 21:33
198 de 3657
Bruce Cohen (NL)
Articles: 310
Count of Thanks: 14
Bruce Cohen
A real bauty it is!
With or without badge...
Thank you
