philips: BX553A (BX 553 A);
? philips: BX553A (BX 553 A);
13.Jan.10 17:53
18
Paul E. Pinyot † 2013 (USA)
Articles: 184
Count of Thanks: 18
Gentlemen,
Where may I find an alignment procedure for this radio chassis?
Thanks,
Paul.
Service manual
13.Jan.10 19:37
18 von 4530
Carlos Alves (P)
Articles: 105
Count of Thanks: 15
Hi Paul,
If you wanted i send to you the service manual but in Dutch.
Best Regards
Carlos Alves
Radiotechniek
13.Jan.10 20:28
33 von 4530
Mario Coelho (P)
Articles: 451
Count of Thanks: 15
Mario Coelho
Dear Paul
You can also see it  in radiotechniek.
Mario
Radiotechniek service manual success.
14.Jan.10 00:04
50 von 4530
Articles: 184
Count of Thanks: 13
Mario and Carlos,
Thank you for the quick replys!
I downloaded a service manual from Radiotechniek and yes it is in Dutch.  I think I can manage through the alignment since there are plenty of similar looking words.
I may come back to this board to ask help with certain sections.  I usually have difficulty with FM alignments just after the ~10.7 MHz IF steps.
Looking at the section for the UL41 tube function is interesting too.
I find the cross cultural/language differences quite challenging, intriguing and enriching.
Has any one tryed to use OCR (optical charictor recognition) software to read these documents then run the results through Google Translate?
Paul.
? Please check translation.
14.Jan.10 07:42
72 von 4530
Articles: 184
Count of Thanks: 13
Would some one please check my translation?
I scanned the Dutch version printed from a PDF with an HP scanner and saved to a Microsoft RTF file.  Cleaned up the type.  Then processed the text with Google Translate ( http://translate.google.com/#nl|en| ).
Please put corrections in a different color (i.e., RED).
This is what I got:
Het afregelen van de ontvanger
A.M. gedeelte
Algemeen
The adjusting of the receiver
A.m. part
Overall
Volumeregelaar op maximum.
Voltmeter via trimtransformator aansluiten op extra luidspreker aan­sluitingen.
Trimpunt 1 ligt Geheel limke op stationsschaal.
Trimpunt 2 ligt juist rechts naast trimpunt 1.
Trimpunt 3 ligt gcheel reckts op de stationsschaal.
Kernen der M.F. bantfilters zo ver mogelijk uitdraaien.
Indien niet anders aangegeven, worden de signalen via een normale kunstantenne aan de antenne bussen toegevoerd.
Volume control at maximum.
Voltmeter using trim transformer connect additional speaker ¬ closures.
Trim Point 1 is far left on drive level
Trim Point 2 is just right trim point 1.
Trim Point 3 is completely right on the station level.
nuclei of M.F. band filters as far as possible from turning.
Unless otherwise indicated, the signals through a normal aerial art buses supplied to the antenna.
(Insert IF table).
M.F. Sper- en zuigkringen
M.F. Lock- and suction circuits
Kernen van S11 en S12 zover mogelijk uitdraaien.
S6-S6a kortsluiten.
Cores S11 and S12 where possible printouts (turning).
S6-S6a short-circuit.
1. Stationswijzer instellen op trimpunt 3.
2. Signaal van 452 KHz toevoeren via normale kunstantenne aan antannebus.
3. S11 trimmen op maximum output.
4. Kern van S11, 1/4 slag doordraaien.
5. S12 trimmen op minimum output.
6. S11 natrimmen.
1. Station Finder trim set point 3 (station pointer to trim set point 3).
2. 452 KHz signal from feeding through mainstream art antenna antannebus.
3. S11 trimming at maximum output.
4. The core of S11, 1/4 turn by turn.
5. S12 trimming output at minimum.
6. S11 after trimming.
(Note on top of table )
Verbinding van antannebus naar punt 11 SK-ant. losnemen.
Connection of antannebus SK-ant to section 11. disconnecting
(Insert HF Oscillator Table)
(Table Heading).
Golfbereik   Trimpunt Signaal Afregelen Indicatie Aanwijzing
Signal Point Golf Range Trim adjusting Designation Indicator
(Note on bottom of table )
Verbinding van antannebus naar punt 11 SK-ant. Weer aanbrengen.
Connection of antannebus SK-ant to section 11. Reapplied
F.M. gedaelte
Het afregelen met behulp van een F.M. Service oscillator
Algemeen
F.M. part
The adjusting using a F.M.
Service oscillator
Overall
Volume regelaar op maximum.
Hoge tonen regelaar op maximum hoog.
Lage tonen regelaar op maximum laag.
Diodevoltmeter via een weerstand van 0,1 M ohm aansluiten over R23.
Voltmeter via trimtransformator aansluiten over extra luidspreker ­aansluitingen.
Tijdens het afregelen dient de uitgangsspanning van de Service oscilla­tor dusdanig te worden ingesteld dat de diodevoltmeter (D. V.) een spanning van ca. 8 Volt aanwijst.
De signalen zijn gemoduleerd met 500 Hz, zwaai 22 ½ KHz.
Treble control on high ceiling.
Bass control on maximum layer.
Diode Voltmeter using a 0.1 M ohm resistor R23 to connect.
Voltmeter using trim to connect additional speaker transformer connections.
While adjusting, the output voltage of the oscillator Service to be established so that the diode voltmeter (DV) a voltage of about 8 designates Volt.
The signals are modulated at 500 Hz, sweep 22 ½ KHz.
Kernen van S21, S27, S31 en S36 zover mogelijt uitdraaien.
Cores S21, S27, S31 and S36 far as possible from turning.
S44 en S44 kortsluiten. (under chassis).
S43 and S44 shorting. (under chassis).
(Insert M.F. band Table here.)
M.F.  sperkringen
Kortsluiting van S43 en S44 opheffen.  (Under chassis).
Antennebussen  kortsluiten.
Signaal van 10.7 MHz zwaai  22 KHz, mod. 500 Hz toevoeren tussen an­tennebus en aarde.
S43 en S44 gelijktijdig aftrimmen op minimum aanwijzing D.V.
M.F. barrier circles
Remove Short circuit of S43 and S44. (Under chassis).
Antenna Buses shorting.
Signal from 10.7 MHz 22 KHz swing, mod. 500 Hz feeding between aerial and earth.
S43 and S44 simultaneously trimming minimum indication on DV
(Insert FM oscillator table).
(Insert table from top of page 5)
Het afregelen met behulp van een A.M.  Service Oscillator
Hoge tonen regelaar op max, Hoog.
Lage tonen regelaar op max, laag.
Ti jdens het afregelen dient de ui tgangsspanning van de Service oscil­lator dusdanig te worden ingesteld dat de diode voltmeter (D. V.) een spanning van ca, 8 Volt aanwijst.
De signalen zijn ongemoduleerd.
The adjusting using a a.m. Service Oscillator
Treble control on max, High.
Bass control on max, low.
While adjusting, the output of the voltage. Service oscillator to be set so that the diode voltmeter (DV) a voltage of about 8 designates Volt.
The signals are unmodulated.
Kernen van S21, S27, S31 en S36 zover mogelijk uitdraaien.
Cores S21, S27, S31 and S36 where possible printouts far as possible from turning
S43 en S44 kortsluiten
S43 and S44 short-circuit
(Insert FM band table).
** Sluit parallel aan C67 twee in serie gesehakslde weerstanden van 250k ohm.
Sluit de D. V. aan tussen het knooppunt van doze weerstanden en het knooppunt R22, C51.
* Verwijder weerstanden van 250 k ohm en sluit de D.V. weer aan over C67.
** Connect parallel to C67 in series two 250k ohm resistors.
Connect the D. V. between the junction of resistors and the junction doze R22, C51.
* Remove 250 k ohm resistors and connect the DV back to about C67.
M.F. sperkringen
Kortsluiting S43 en S44 opheffen.
Ongemoduleerd signaal van 10.7 MHz toevoeren tussen antennebus en aarde.
S43 en S44 galijktijdig aftrimmen op minimum aanwijzing D.V.
Short circuit S43 and S44 removal.
Unmodulated signal of 10.7 MHz feeding between aerial and earth.
Aandrijfsnaren
De lengte en de loop van de aandrijfsnaren zijn gegeven in fig. 5. De variabele condensatoren zijn hierbij in maximum stand getekend.
Driving Strings
Thelength and the course of the drive strings are given in figure 5.
The variable capacitors are hereby signed in maximum position.
Aandrijfmechanisme
Bij het indrukken van de druktoets voor de F.M.  ontvangst wordt het
aandrijfmechanisme van de A.M. afstemcondensator ontkoppeld en de
aandrijving voor de F.M. afstemcondensator ingeschakeld.
Op A.M en F.M. kan hierdoor due met hetzalfde bedienings organ
worden afgestemd.
Drive Mechanism
By pressing the push button for F.M. the host
drive mechanism of the a.m. decoupling capacitor and the
drive for F.M. switched capacitor.
On A.M and F.M. may result due to same control
are aligned.
? Translation correction
14.Jan.10 13:05
98 von 4530
Dirk Taekels (B)
Articles: 46
Count of Thanks: 12
Dirk Taekels
Hi Paul ,
I made corrections on your translation.
I hope that this can help you !
kind regards,
Dirk
This is what I got:
A.M. gedeelte
Algemeen
A.m. part
Overall
Trimpunt 1 ligt Geheel links op stationsschaal.
Trimpunt 3 ligt geheel rechts op de stationsschaal.
Kernen der M.F. bandfilters zo ver mogelijk uitdraaien.
to the  additional speaker connections.
Trim Point 1
as far as possible to the left side of the dial scale
Trim Point 2 is just on the right side of trim point 1.(just near the point 1)
Trim Point 3
is completely on the right side of the dial scale.
Turn the ferrite cores of the bandfilters as far as possible ccw.
Unless otherwise indicated, the signals are applied through a normal aerial on the  the antenna connections.
(Insert IF table).
M.F. barrier- and suction circuits
S6-S6a kortsluiten.
Turn cores S11 and S12 as far as possible ccw .
S6-S6a  shorting.
6. S11 natrimmen.
1. Set the dial scale to the Trim    point 3 position.
2. Apply a 452 KHz signal to the  antenna connections .
3. S11 trimming to have the  maximum output.
4. Turn the core of S11, 1/4 turn cw.
5. S12 trimming to have the  minimum output.
6. Readjust S11!
Disconnect  antenna-connection  to point 11t.
(Table Heading).
Wave range  Indication of adjusting of Trimpoint signal
Reconnect antenna-connection to point 11.
F.M. gedeelte
Algemeen
F.M. part
Service oscillator
General
Diode Voltmeter using a 0.1 M ohm resistor parallel on  R23.
Connect the Voltmeter using a trimtransformer to the additional speakerconnections.
While adjusting, the output voltage of the Service oscillator has to be adjusted  so that the diode voltmeter (DV) read a voltage of about 8 Volt.
Turn cores S21, S27, S31 and S36 as far as possible ccw.
M.F.  sperkringen
M.F. barrier circuits
S43 and S44 simultaneously trimming to have a minimum indication on DV
The adjusting by using a a.m. Service Oscillator
While adjusting, the output voltage of the Service oscillator has to be set so that the diode voltmeter (DV) read a voltage of about 8 Volt.
** Sluit parallel aan C67 twee in serie geschakelde weerstanden van 250k ohm.
Sluit de D. V. aan tussen het knooppunt van deze weerstanden en het knooppunt R22, C51.
** Connect parallel to C67 two resistors of 250K ohm (who are in series) .
Connect the D. V. between the junction of this two resistors and the junction of R22, C51.
* Remove the  250 k ohm resistors and reconnect the DV back to C67.
M.F. sperkringen
Remove shorting on circuit S43 and S44.
Apply an unmodulated signal of 10.7 MHz signal between aerial and earth.
Aandrijfsnaren
Driving Strings
The length and the course of the drive strings are given in figure 5.
Aandrijfmechanisme
Op A.M en F.M. kan hierdoor met hetzelfde bedieningsorgaan
worden afgestemd.
Drive Mechanism
By pressing the push button for F.M. , the drive mechanism of the A.M. is decoupled while
the drive for F.M. is coupled .
In this case the AM and the FM drive commands can be done using the same mechanism.
Answer
20.Jan.10 11:53
206 von 4530
Articles: 2316
Count of Thanks: 12
I think the matter is finished and therefore no question any longer.
Thanks for the contributions.
Thanks Dirk
26.Jan.10 04:51
292 von 4530
Articles: 184
Count of Thanks: 13
Dirk,
I completed the alignment tonight.  Your translation corrections were a big help.  Thanks again for the corrections.
Now I need to find a Bass control poteniometer.
Paul.
