philips: BX998A; Bi-Ampli
01.Jun.11 21:26
99
Henk van 't Kruis (NL)
Articles: 4
Count of Thanks: 17
Henk van 't Kruis
On request I started with the translation of the BX998A from Dutch into English. within 2 weeks the document is ready for the users here.
Also I just have revised a BX998A and is works like it was, just from the factory. I will store here the restoration story also.
gr. Henk
translation
07.Jun.11 19:10
99 von 3559
Paul E. Pinyot † 2013 (USA)
Articles: 184
Count of Thanks: 10
gr. Henk
Have you comlleted the translation of the alignment instructions?  I am starting the alignment today.
First I am replacing all the bad or carboned lamps.  Wow, it is not simple.  There are different voltage lamps.  Some appear to be in series.  soback to the shemativcs for now.
Paul
Update:  I managed to complete the IF and AM band alignments last night found on page 8.  It was relatively easy to deduce the Band, Frequency adjustment points and the intended adjustment.  I need to complete alignments from page 9 and beyond.
One difficulty is not knowing where to set the band width.  So I set it in the middle at the "dart" or diamond point in the middle of the scale.
My translation has both Bass and Treble set to minimum for the 452 khz IF alignment.
Today I will try and translate pages 9 and perform the alignments.
English documents
15.Feb.15 09:52
888 von 3559
Thomas Engelhardt (D)
Count of Thanks: 13
Thomas Engelhardt
Hello Henk,
I have recently purchased a Bi-Ampli 998A and noticed the related documents on this site are all in Dutch. Since I saw your post from about 4 years ago on translation into English, I kindly would like to ask if you could provide me with a copy?
In advance thanks for your help!
Regards
Thomas
BNX998A
15.Feb.15 20:55
948 von 3559
Articles: 4
Count of Thanks: 12
Henk van 't Kruis
Hello Thomas,
Tomorrow, I will place the article on RMORG.
