philips: PHILIPS 2510
- Philips 2510 Schematic (132 KB)
         Hi, José,
if You are not able to obtain the requested Tube, or if it's just too expensive, then You may wish to use a modern Type Tube instead.
There is a "PL95", designed for AF Output Amplifier, used in TV Sets . The Heater is 4,5 Volts / 0,3 Amp, this shoud work in Your Radio. The Grid Voltage needs to be adjusted to have the correct Anode Current.
You may try to find such Tube at Your prefered Tube Dealer. If You cannot find this Toube, then i have a few used ones, which i can ship to You, if You like.
If You need further Assistance, please let me know.
Best Regards from Germany,
Henning
The
         Hi Henning:
Thanks for your kind and soon answer.
Yes, it is an option. I used a 42 tube and works good (on despite of the heather voltage).
But I would like putting the old tube keeping the originality of the radio, and install an hidden transistorized amplifier (at bottom of the chassis).
Thanks again.
José from Chile
