philips: Philips PL1/01
This article refers to the model: Signalmaster All Transistor PL1 /01 (Philips Australia)
? philips: Philips PL1/01
06.Nov.17 09:16
32
Hi,
I just bought a Philips PL1/01. It looks the same but has later (AF116, AF116, AF117, AF117, AC126, OC74N, OC74N) transistors. I cannot find a circuit to check for possible other differences.
Do you want it as a separate model or an addendum to the standard PL1?
Thanks
jim
- PL1/01 Label (147 KB)
- Philips PL1/01 Front (198 KB)
New model
06.Nov.17 12:13
32 from 1321
Hi Jim,
thank you for your question.
Since your radio has a different model no. designation and transistor line-up it's indeed a new model for RMorg. Year can be set to 1966 with one year of uncertainty. Please make your suggestion, thanks a lot.
Bernhard
