philips: VE1306/04 ;
This article refers to the model: VE1306/04 (Philips Radios - Deutschland)
? philips: VE1306/04 ;
10.Oct.11 10:36
Cetin Gursel (FIN)
Articles: 2
Count of Thanks: 5
Hello,
I have a Philips VE1306/04 tube amp. I am going to replace filter caps. Two times 25uf+25uf 385V. I only can find 33uf+33uf in local shop. Is it possible to use it instead of 25uf+25uf?
Regards
Cgursel
VE1306/04
10.Oct.11 11:38
15 von 2588
Jan Terranea (NL)
Articles: 63
Count of Thanks: 11
Jan Terranea
The specific rectifier-valve restricts the maximum capacity for the electrolyt.
This value can be found in an electronic valva databook.
Nominal values on electrolytic capacitors often are not very precise.
A nominal 25 microfarad item could be about 33 micofarads in reality.
10.Oct.11 21:33
63 von 2588
Walter Haring (CH)
Articles: 214
Count of Thanks: 4
Walter Haring
Hello
This amplifier uses a selenium rectifier. So using a 2 x 33 uF electrolytic will be fine.
Concerning selenium rectifiers please note specially post 4 of Mr. Knoll in the link
Kind regards, Walter Haring
10.Oct.11 23:14
75 von 2588
Cetin Gursel (FIN)
Articles: 2
Count of Thanks: 6
