Replace EY82 with EY80
Este artículo se refiere al componente: Ir a la válvula/semiconductor
? Replace EY82 with EY80
12.Apr.20 19:52
Joaquín Méndez (E)
Agradecimientos totales: 9
Could you use this EY80 valve (damper, booster, flyback diode on TV receivers) as a normal rectifier on a radio receiver, to replace an EY82, to get 180mA at 250v? Thank you.
12.Apr.20 20:36
8 von 1423
Moderador
Artículos: 1775
Agradecimientos totales: 8
Hello Joaquín,
yes, this should work. The EY80 can withstand a much higher peak inverse voltage as the EY82.
Best Regards,
Jacob
