atwater: Request for help_ Resistance values
? atwater: Request for help_ Resistance values
12.Jul.22 17:26
Júlio Branco (P)
Articles: 206
Count of Thanks: 7
Júlio Branco
Dear radio friends
I'm trying to recover an AT Wather model 137 Cathedral Cabinet style radio I came across a problem, the resistors have unusual codes, that is, some have two colors, others with one and the value of some for example R4 : .5 Ohm on the contrary and R15= .1 Ohm on the contrary, (Ω ), can any of your friends help to read the real value of these resistors, or if there is any common factor of multiple or divisible depending on what appears in the diagram?
Please see this schematic scrap I prepared
A big thank you in advance
From Portugal
Júlio Branco
/forumdata/users/3656/AT_Wather_137.jpg
12.Jul.22 17:36
5 from 2444
Tomasz Szczesniak (PL)
Articles: 95
Count of Thanks: 11
Most probably this values are in Megaohms (MΩ). Notice the Ohm symbol on this resistors - is printed upside down: ℧.
13.Jul.22 14:02
74 from 2444
Rolf Beckers (D)
Articles: 230
Count of Thanks: 9
Rolf Beckers
Dear Julio,
In most old diagrams resistors are either in single Ohm e.g. 100 = 100 Ohm or 25,000 = 25kOhm. Or they come with a leading dot in MegaOhm .5 = 0.5 MOhm. The numbers of the color code are similar as today, but there are no rings, see attached table. Most old resistors are colored as shown left above.
Regards,
Rolf
13.Jul.22 16:35
107 from 2444
Lars-G. Lundelin (FIN)
Articles: 145
Count of Thanks: 9
Atwater Kent used their own color codes for certain resistor values. You will find codes in the following
link:
atwaterkent.info/TechData/Images/SM3501_013.gif
Regards
Lars-G
14.Jul.22 09:44
175 from 2444
Júlio Branco (P)
Articles: 206
Count of Thanks: 11
Júlio Branco
Dear Tomasz
Thank you very much for the information, I have confirmed that the position of this inverted symbol is read in MOhmos.
Júlio Branco
