grundig: Request for info
? grundig: Request for info
18.Dec.16 11:23
70
Georges Van Campenhout † 28.4.22 (B)
Articles: 202
Count of Thanks: 19
Dear radio friends,
I have currently such a radio under restoration. I am looking for the aligning data. Can anyone provide this info, please?
I am also looking for technical info about the loudspeakers that have been used in this set. There are in total 6 speakers: 2 electrostatic tweeters, 2 elliptical medium, one large and one smaller woofer.
And my last question: what Grundig Ferndirigent model had to be used with this radio?
Thank You
Probably model 3035/56 matches
19.Dec.16 23:21
70 de 1816
Officer
Articles: 1676
Count of Thanks: 15
Most probably Grundig's table-model 3035/56 shares the same chassis as your Konzertschrank 8090/56 does have. There you also will find an alignment chart and other helpful stuff. Only the audio output transformer and loudspeaker layout differs. Sorry, only in German...
Both models seems to have the same circuit design in FM and AM section. It's somewhat special because the FM IF section uses the reflex priciple for the 1st IF stage. One half of the ECC85 acts as RF preamplifier and afterwards as the 1st IF amplifier stage.
Good luck!
