saba: 14 Stereo; Freiburg Vollautomatic search oscillation problem
This article refers to the model: Freiburg Vollautomatic 14 Stereo (SABA; Villingen)
? saba: 14 Stereo; Freiburg Vollautomatic search oscillation problem
18.Jul.13 19:06
25
Bryan McAlley (GB)
Articles: 40
Count of Thanks: 17
The search engine on my Freiburg oscillates around each station and the tuning knob constantly moves backwards and forwards unless I turn the auto search off. I have cleaned all the sets of conacts behind the control buttons, but the probem still persists.
Any idea what the probem might be please?
Bryan
Die Suchmaschine auf meinem Freiburg schwingt um jede Station und die Tuning-Knopf bewegt sich ständig hin und her, wenn ich die Auto Suche ausschalten. Ich habe alle Arten von conacts hinter den Bedientasten gereinigt, aber das probem noch besteht.
Irgendeine Idee, was das sein könnte probem bitte?
Bryan
Shiver
18.Jul.13 22:44
25 de 3634
Rüdiger Walz (D)
Officer
Articles: 716
Count of Thanks: 19
Rüdiger Walz
Dear Bryan,is it really an oscillating  or is it a shiver / vibration forward and back ? The automatic kepts the radio optimal tuned and to avoid a disturbance by the mechanical parts it always vibrates a little bit forth and back around the station. This should have no audible or variantion in tuning (magic eye) effect. Otherwise it is a failure of the system.
Tuning oscillation
18.Jul.13 23:49
34 de 3634
Bryan McAlley (GB)
Articles: 40
Count of Thanks: 20
Dear Rudiger,
It's an oscillation, rather than a shiver, but I think I know what the problem is now. I thought by drawing a piece of paper impregnated with Deoxit through the contacts, they would be sufficiency clean to work - but having gone back and checked them all again with my Avo, some are not all making contact  when they should be.
So - tomorrow  I'm taking out the switch unit and systematically cleaning and adjusting each set until they work properly!!
Any ideas about the best way to clean the contacts? Very fine wet and dry sandpaper??
Many thanks,
Bryan
Contacts
19.Jul.13 21:35
61 de 3634
Rüdiger Walz (D)
Officer
Articles: 716
Count of Thanks: 13
Rüdiger Walz
Yes, fine sandpaper is ok. In Germany the numbers are 600, 900 or very fine 1200. If you have to use contacts spray which chemically solves the oxide coating of the contacts you should always clean them with a neutral solvent afterwards. Otherwise they will corrode very fast due to residues of the contact spray.
