saba: 6-3D (6-3 D); Meersburg-Automatic
This article refers to the model: Meersburg-Automatic 6-3D (SABA; Villingen)
09.Mar.10 11:09
4104
I have found, I believe, errors in the schematic. The schematic is dated 12.5.55. The schematic shows the voltage "m" as -9 vdc and the voltage "V1" as -3.5 vdc. I believe voltage "m" should be about -16 vdc and "V1" should be about -8.7 vdc. Voltage "V2" should be about -1.4 vdc.
Finally, the switch labeled "K5", should be labeled "K4".
