saba: FD 16 Stereo; Freudenstadt
This article refers to the model: Freudenstadt FD 16 Stereo (SABA; Villingen)
? saba: FD 16 Stereo; Freudenstadt
06.Jul.12 23:49
Daniel McGrath (USA)
Articles: 2
Count of Thanks: 17
The power transformer in my SABA FD 16 is dead.  It is reading 37 meg ohms across the plug pins.
All tubes were removed.  Can someone let me know where I can purchase a replacement transformer.
Thank you.
Dan
Checking
07.Jul.12 00:27
2 de 3656
Michael Watterson (IRL)
Articles: 1126
Count of Thanks: 14
Did you check directly at the transformer primary connections under the voltage selector and at transformer to eliminate possibility of fuses,  voltage selector, on/off switch or other wiring problem?
As requested
07.Jul.12 02:18
25 de 3656
Articles: 2
Count of Thanks: 13
Yes, I had removed the voltage selector.  It's remarable that you mentioned a wiring problem because this radio and a on-off switch in the back (simple toggle switch) because someone did not want to repair the on off switch at the front of the radio.  Yes I need a replacement transformer.   If you have suggestions I would be most grateful.
