saba: Saba Freudenstadt FD18 Instructions
? saba: Saba Freudenstadt FD18 Instructions
14.Apr.23 03:03
84
Henry Saam (USA)
Articles: 8
Count of Thanks: 1
Hello,
I would like to know how to select the Tape input of the FD18 input. I see that there is a click button for Phono input selection but seems no buttom for Tape input?
Also very much appreciate any instruction manual and technical specs of the radio if this exists.
Thanks,
Henry Saam
15.Apr.23 08:06
84 from 889
Henning Oelkers (D)
Articles: 604
Count of Thanks: 2
Henning Oelkers
Dear, Henry,
on this Model the Phono Pushbutton is used for both, the Record Player and a Tape Recorder. This was comon on many Models of that Time.
Best Regards,
Henning
19.Apr.23 23:28
199 from 889
Henry Saam (USA)
Articles: 8
Count of Thanks: 2
Dear Henning,
Many thanks for your kind reply and apologies for the delay as I just saw your post. Indeed I used the Phono push button and the tape input started playing!
It is interesting that they shared the same button which suggests you can connect only one source in the back and not two, is that correct? Or perhaps the input circuitry has a sensing mechanism and if one input is turned off it is ignored?
Best,
Henry
