saba: SABA Wildbad 125 - sprache-music switch
This article refers to the model: Wildbad 125 (SABA; Villingen)
? saba: SABA Wildbad 125 - sprache-music switch
01.Jul.16 22:46
John Fedak (CDN)
Articles: 4
Count of Thanks: 10
Need help - my Saba works very well, with one exception -
The switch over from sprache/music is ot working. it stays in music mode.
Is it a mechanical problem or is it an electrical problem? I think it is electrical, however I am not sure.
Would  some one help me on this issue? Thank you, Viellen Dank, John Fedak
This thread was moved automatically.
This question was moved automatically to the board "Talk" to get more possibilities for answers.
Moved from board »* TALK - visible for members only« on 07.07.2016 22:46:54 from automatically
Saba Switch Concept
10.Jul.16 20:35
192 from 2107
Henning Oelkers (D)
Articles: 585
Count of Thanks: 11
Henning Oelkers
Hi, John,
Saba has a special Switch Behavior on some Models.
If You push the Switch slowly downwards, you schould hear a click, short before reaching the max travel.
if You leave the Button, it schould stay in the lower position. If You push further down, the Switch is released again, and then moves back to the up position.
Many People just push the Button all the way down, which initiates a release and the Button didn't stay in the lower position.
maybe this helps,
Best Regards,
Henning
Moved from board »* TALK - visible for members only« on 01.Aug.16 23:53 from Otmar Jung
