saba: SABA Wildbad 125 - sprache-music switch
? saba: SABA Wildbad 125 - sprache-music switch
Need help - my Saba works very well, with one exception -
The switch over from sprache/music is ot working. it stays in music mode.
Is it a mechanical problem or is it an electrical problem? I think it is electrical, however I am not sure.
Would some one help me on this issue? Thank you, Viellen Dank, John Fedak
This thread was moved automatically.
Saba Switch Concept
![Henning Oelkers](https://www.radiomuseum.org/image.cfm?image=d_henning_oelkers_2001.jpg&width=120&height=140)
Hi, John,
Saba has a special Switch Behavior on some Models.
If You push the Switch slowly downwards, you schould hear a click, short before reaching the max travel.
if You leave the Button, it schould stay in the lower position. If You push further down, the Switch is released again, and then moves back to the up position.
Many People just push the Button all the way down, which initiates a release and the Button didn't stay in the lower position.
maybe this helps,
Best Regards,
Henning
