schaub: 70 Universal; Touring - Carrying Handle Removal
This article refers to the model: Touring 70 Universal 110151 / 110153 / 110154 / 110156 / 110157 / 110159 (Schaub und Schaub-Lorenz)
? schaub: 70 Universal; Touring - Carrying Handle Removal
01.Sep.13 06:27
279
Hello:
How do I remove the carrying handle from my Schaub Lorenz T70 Universal?
Also, will the carrying handle from this radio also fit on a T80 Universal?
Many thanks,
Mike Witas
Milwaukee, Wisconsin USA
Lifting the Cover
02.Dec.13 01:39
279 de 3266
Hi, Michael, As far as i remember, the Handle is mounted from the inside of the Cover. You will need to remove the knobs for Volume and Station, and 4 Screws on the underside of the Radio. The Screws are apx 5cm from either Side of the Radio, two are close to the Front Grill, the other two are close to the back. Then You schould be able to lift the Cover off the Chassis. You may need to hold the Chassis down by the axes of the knobs, while lifting the Cover with the Hanle. Hope this helps, Best regards, Henning
Removing the carrying handle
25.Apr.15 14:24
622 de 3266
Helmut Lemburg (D)
Count of Thanks: 9
Count of Thanks: 9
Hi Michael,
the question is long time ago but I like to answer because of two remarks.
1. The handles are the same from Touring 70 and 80
2. It is not necessary to remove the cover. You need only to pull carefully in the direction away from the Radio.
Attachments:- Schaub-Lorenz Touring 70 Housing inside (283 KB)
- Schaub_Lorenz_Touring70_Handle_open (289 KB)
