philips: Schwebungssummer GM2308
? philips: Schwebungssummer GM2308
08.Nov.19 00:14
34
Julian Hardstone (GB)
Articles: 7
Count of Thanks: 5
Julian Hardstone
What is a Schwebungssummer? I presume this is a German word but dict.tu-chemnitz.de can only tell me that Schwebung is a frequency-beat.
The GM2308 should be called a Toongenerator or Signal Generator, not Schwebungssummer. A signal generator does not itself generate 'tone beats' it provides one of the tones from which another equipment can generate beat-notes.
I see from the onderwijs manual posted here that the manufacturer calls it simply Philips Toongenerator GM2308 and nowhere mentions Schwebungs
Thanks for giving all the information and images of this model - Julian
08.Nov.19 11:54
34 von 3038
Wolfgang Holtmann (NL)
Articles: 996
Count of Thanks: 7
Wolfgang Holtmann
Hello Mr. Hardstone
The German expression "Schwebungssummer" means simply that the generated LF is the result of internal mixing of two frequencies!
One oscillator is tunable between 85 and 100kHz, the other from 100 to 101kHz. By this manner the tone beats are in the LF range of 0 to 16kHz which can be obtained without switching, indeed a great advantage....
Kind regards
more Schwebungssummer's
09.Nov.19 07:46
132 von 3038
Articles: 996
Count of Thanks: 5
Wolfgang Holtmann
For additional clarification,
may I draw Your attention to the GRUNDIG Beat Frequency Oscillator Type 295.
Using the same working principle by mixing two HF frequencies and cut out the unwanted remains with a low pass filter.
Also MARCONI produced one called TF 601A.
Kind regards
10.Nov.19 19:46
251 von 3038
Georg Richter (D)
Articles: 909
Count of Thanks: 12
Georg Richter
Gentlemen,
please let me join the discussion.
At first, it does not matter how other manufacturers are naming similar models.
At second,  RMorg shall be as precise as possible.
The uploaded catalogue sheet names GM2308 simply "Tongenerator".
Same in the Netherlands instruction manual: "Toongenerator"
This US model has correct name "Beat Frequency Oscillator" which was extended with "Schwebungssummer" in brackets by any reason.
So I would suggest to change GM2308 model name to original. If you insist  with "Schwebungssummer" in brackets.
But I have to remark that French and english speaking members do not understand "Schwebungssummer".
In 2006 the model was accepted as "Tongenerator (Toongenerator)", in 2008 changed  to "Schwebungssummer".
Best Regards,
GR
12.Nov.19 22:33
327 von 3038
Georg Richter (D)
Articles: 909
Count of Thanks: 8
Georg Richter
Meanwhile the model name was precised  to
"Tongenerator / Toongenerator (Schwebungssummer) GM2308"
It shall be recognized that "Schwebungssummer" ist not the only purpose.
I hope that all are satisfied now.
Best Regards,
GR
12.Nov.19 23:21
335 von 3038
Articles: 7
Count of Thanks: 4
Julian Hardstone
Many thanks for the change. Do we now have two German names? I don't know your naming conventions, but I see you use English for other signal sources, like TF2100 or TF2102M
