sony: Sony ICF-110B/W: 70''s components with the 60''s flavor
This article refers to the model: IC-11 3Band IC+FET ICF-110W (Sony Corporation; Tokyo)
30.Jun.21 13:04
666
The loudspeaker is a genuine Japanese part with atention to detail -  look to the position of the ground terminal, close to the ground plane of the PCB.
The miniature tone potentiometer is a replica of the larger volume pot, very well designed and built to last.
The two position power On/Off switch is a miniature brute force design, easily serviceable if needed.
And the Tuning Meter design where the rest position of the meter hand is on the right side of the scale - A japanese part as well.
Kind of 60's flavor in technological terms.
