sony: Sony ICF-7800 speaker foam failure. Easy repair?
? sony: Sony ICF-7800 speaker foam failure. Easy repair?
22.Jul.21 11:42
Jose Mesquita (P)
Articles: 111
Count of Thanks: 8
Jose Mesquita
I have recently acquired a Sony ICF-7800 in a so-so condition. It is working on all bands, despite some non identified issues on SW and MW bands where the symptoms are whistling around the tuned stations and loss of sensitivity (to be looked for at a later time).
The main issue is the speaker that shows a total foam ring degradation, unable to handle any level of bass. Treble works fine, though.
I have disassembled the radio to remove the major part of the damaged foam ring from the speaker, most of it freely laying around the enclosure.
Do you know of suitable speaker foam ring parts for this speaker? I found a few references in the Internet, but I wonder where these really are adequate.
Back cover removed to expose the speaker details:
  • SONY
  • 1-502-598-11
  • 1.4W 6.5 Ohm
  • 0837
  • JAPAN
  • J020
22.Jul.21 13:40
16 von 2544
Articles: 2441
Count of Thanks: 9
You will find here in "Lautsprecher Reparatur" a method described, that works.
Regards, Dietmar
29.Jul.21 14:54
151 von 2544
Jose Mesquita (P)
Articles: 111
Count of Thanks: 12
Jose Mesquita
Meanwhile I think I was lucky to find a probable candidate to replace the damaged foam ring at the global auction website from a seller nicknamed as "scarlettchen" based in Hong Kong under the item number 122725139059.
Now I still have to find a way to remove the cardboard ring from the speaker without destroying it, in order to be able to install the new foam ring and put it back over the new foam ring.
