Technics SL-BD22
Technics SL-BD22
Hello dear all,
I have a audio-turntable Technics Model SL-BD22 and the drive belt is not in place, I make a search in the Rmorg and cannot find this model... anyone can help me please with some data and the schematic or the best way to put the drive belt in place?
Thanks in advance,
Vitor
Jeff
Better you upload the model
You are very active in RMorg and have uploaded about 3000 pictures and 1223 schematics, congratulations.
You have entered also about 2000 new models and made 14470 changes to models. Therefore we will naturally try very much to help you - but please enter the model and load up the pictures to the model. Then you can ask me to move this to the model and I will remind our community with anotehr post to it. Thank you.
This is a brandnew model.
The belt will be mounted on the underside of the turntable to the driving pinion.
Regards WB.
Technics LP Player
it seems to me that I use the same or a similar model since two years, see the attached picture.
If you need more information or more photos from inside, please tell me.
Best regards
Rolf
Thank you all for try help me.
Dear Wolfgang, thank you for the explanation about the belt in your nice pic, anyway I try to put the belt in place like you show here and seems are bigger for the place! Any idea please?
Dear Rolf, yes please I'm greatful if you can send me a pic with the belt in place.
Dear Erb, I uploaded right now the model...
Thanks,
Vitor
Beltdrive
I think Wolfgang's picture shows exactly the run of the belt, sea also my detail-photo and the overview. The belt runs round the bottom of the turntable and the drive wheel only, there are no further "points of touch".
Might be that the belt you got does not fit, e. g. it is too long.
Best regards
Rolf
belt
Thank you all,
Yes, seems the original belt is now too long becouse it was just growing by age!!
It is normal? I think the solution for the problem is buy another belt for this model, any link please?
all the best,
Vitor
Hallo Mr. Oliveira,
your belt has the size:
186mm x 4mm x 0,6mm. (flat)
You can get it in every repair shop for Radios and TV.
They can order it for you.
Regards WB.
