tektronix: 212; Oscilloscope
This article refers to the model: Oscilloscope 212 (Tektronix; Portland, OR)
24.Sep.15 12:10
36
Pius Steiner (CH)
Articles: 345
Count of Thanks: 10
Das Gerät hat keine externe DC Versorgung, sondern lässt sich nur über eine AC Versorgung speisen. Anbei die Beschreibung aus den Verkaufsunterlagen von 1974:
Power Sources
An internal DC source provides up to 5 hour operation (214 stored mode, up to 3.5 hours). Operating time depends on trace intensity, operating temperature and temperature during previous battery charge. Maximum operating time is achieved at +20°C to +30°C charge and operating temperature. Internal charger provides for charging the batteries when connected to an AC line with instruments turned off. DC operation is automatically interrupted when battery charge drops to approximately 10 volts to protect batteries against deep discharge. Full recharge requires approximately 16 hours (214, 8 hours). Extended charge times will not damage the batteries.
Power Sources (212 and 214)
A pilot light battery-charge indicator light will extinguish when approximately 10 minutes (5 minutes for the 214) of scope operating time remains in the batteries.
Power Source (211)
A battery meter indicates full charge at 15 volts and discharged at 10 volts.
External AC Source
110 to 126 volts, 58 to 62 Hz, (212 and 214, 3 W; 211, 2 W or less at 126 volts). Can be operated at 104 to 110 volts with resulting slow discharge of internal batteries.
Power Options
24.Sep.15 16:22
36 de 4063
Officer
Articles: 1737
Count of Thanks: 9
Tektronix lieferte das Oscilloscope 212 mit 3 verschiedenen Netzlade/Akkupacks, um es weltweit einsetzen zu können. Die sog. Power Options mussten bei Bestellung ausgewählt werden und waren nicht umschaltbar.
Neben der Standard-Version für z.B. den U.S. Markt (im Eingangspost beschrieben) waren folgende zwei Optionen wählbar:
50 (48 to 52) Hz Power Options
Option 1 for 220 to 250 V, including batteries
Option 2 for 90 to 110 V, including batteries
Die Ladeschaltung für die interne Akku-Batterie (vom TEK 214) ist denkbar einfach aufgebaut:
Charging circuit for the TEK 214 Oscilloscope
Funktion Laden: Nach einem Netzfilter und einem Vorschaltkondensator C210 folgt ein Brückengleichrichter der den Akkupack auflädt. Bei Netzbetrieb (S 215 on) des Oszilloskopes wird ein weiterer identischer Vorschaltkondensator C212 zum C210 parallel geschaltet, um ein teilweises Entladen des Akkus zu vermeiden. Bis zum Akku gibt es zunächst keine galvanische Netztrennung! Diese folgt erst im Trafo des Gleichspannungswandlers (DC-DC Converter), der aus der Akku-Spannung die verschiedenen Betriebsspannungen erzeugt.
Der Wert von C210 bestimmt also den Ladestrom und muss an die vorhandene Netz-Frequenz und -Spannung angepasst sein: ** Selected for Line Voltage Range
