tektronix: 502; Oscilloscope Trigger Amplifier Tube protection
This article refers to the model: Dual-Beam Oscilloscope 502 (Tektronix; Portland, OR)
19.Jul.11 12:32
2728
Pius Steiner (CH)
Articles: 343
Count of Thanks: 33
Here is a simple modification to protect the Type 502 trigger amplifier tube (V24) from high amplitude signals when used with external trigger input.
Locate R10, a 1-meg, 1/2 watt, 10% resistor. This resistor runs from ground to a point on the TRIGGER SELECTOR switch. From this point a wire strap connects to the PLUS-MINUS switch. Replace this strap with a 470-k, 1/2 w, 10% resistor shunted by a .001-uf, 500-v discap.
Type 502's with serial numbers above 623 do not require this change.
Source: ServiceScope Aug 1960
