telefunken: 401; Bajazzo Universal
- picture (76 KB)
Skalenseilscheibe entfernen
Hello,
I don't own this model, but know a few models that were built in this years in a similar way. All these models have nearly the same print and a large plastic frame (mounting chassis). The quad variable condenser block is soldered on the print and the scale wheel is fixed with a center screw (through a hole in the plastic frame). This scale wheel has to be pulled away - after turning off this screw - some millimeters off the quad condenser. May be that there are another two small screws to fix the condenser; these need to be removed, too. Please fix the scale wheel with adhesive tape at the frame and try to remove the print carefully - only the cables for antenna, speaker and battery / power supply will be still connected with the print.
Hopefully it will help... best regards,
Guenther Stabe
Telefunken Bajazzo 401
Hello Mr. Stabe,
Thank you very much for your help. I will open the radio again this weekened and repair it as suggested by you.
Best Regards,
Ashis
Telefunken Bajazzo Universal 401
Hello Mr. Stabe,
Once again thanks for your help. I figured it out how to take the chassis out. It was a very different, simple and practical way to take the whole thing out. Only german radios were made like this those days. I will post the pictures some time on this Radio's page.
Best Regards
Ashis
